Knock Knock!! - Page 4 - Subaru WRX Forum
 33Likes
post #46 of 74 Old 09-18-2014, 12:20 PM Thread Starter
Epictofer's Avatar
lol no broken tools yet! But im lucky enough to have all the subaru special tools on hand.
Epictofer is offline
post #47 of 74 Old 09-18-2014, 10:10 PM
Originally Posted by Epictofer View Post
Motor is torn down. Havent split the block yet, but on cyl 3 i can wiggle the connecting rod where it connects to the crank. I ordered manly pistons, h-tuff rods, and king bearings along with a killer b oil pickup and baffle. Anyone know the difference between an sti oil pump and a wrx one? they look the same but have different part numbers. Once i split the block ill see what kind of condition the crank is in, and probably have to order another one.
Manly pistons, are they MANLY?... I wanna say 15010AA360 is the part number for your car on the oil pump. It should be the same for the WRX and STi unless they bumped the pressure in the STi with duel AVCS..Are you going to reuse that crank as well?
post #48 of 74 Old 09-19-2014, 07:00 AM Thread Starter
Epictofer's Avatar
Ive got another wrx crank and block sitting in the shop also has a spun bearing. ill take em both out and look to see if there is any damage, and if there is i will be getting a new one. my budget is about 2500.00 and im up too about 1250.oo so far. My pistons are going to be so manly it hurts! 8)! the STi pump is a different part number i think. Im going to call tech-line at some point and see what the difference is. I'v seen some kits suggesting the sti pump, so i want to find out why!
post #49 of 74 Old 09-19-2014, 07:07 AM
AllExtinct's Avatar
Screw it, don't risk putting a used crank in just grab up a new one.
OEM around $300
AllExtinct is offline
post #50 of 74 Old 09-19-2014, 07:40 AM
OEM around $300
^^^This.
Appearance isn't a good way to judge if a part is good or not. When in doubt take it to a machine shop and have them check it. Would you really wanna gamble another motor on it?
post #51 of 74 Old 09-19-2014, 08:06 AM Thread Starter
Epictofer's Avatar
Yeai agree with both of you. My stubborn ass father on the other hand swears the crank will be ok because its nitrided at the factory. Today i will convince him otherwise. Hes also my boss/service manager so yaaaayy
- not sure if i lay the sarcasm on thick enough up there~^
post #52 of 74 Old 09-19-2014, 08:13 AM
AllExtinct's Avatar
ESP. When the crank is the heart of the motor pretty much.
Once again if a motor has a spun bearing anything that comes into contact with oil is pretty much useless or will require more time and money to fix.
Your doing good on your budget, don't take any shortcuts and you'll be fine.
Epictofer likes this.
post #53 of 74 Old 09-30-2014, 04:25 PM Thread Starter
Epictofer's Avatar
Got some parts porn for you guys! process has slowed down a bit, we have been really busy. gonna crack the block apart tonight. cyl 3 spun the bearing. good bit of movement there.
post #54 of 74 Old 09-30-2014, 05:48 PM Thread Starter
Epictofer's Avatar
going to order the crankshaft tomorrow. Both of the ones i have are no good. Also going to order the STI oil pump, although i havent found a legit reason why. Im assuming it pumps more volume of oil but i dont know for sure. Anyone have any insight?
post #55 of 74 Old 09-30-2014, 11:49 PM
Not sure about the STi oil pump, but I did the same thing. The "bigger is always better" idea convinced me I guess.
post #56 of 74 Old 10-01-2014, 05:25 PM
The newer STi pump is a 11mm rather than the crappy 10mm they use to come with. It is also designed to flow more oil due to the dual AVCS in the newer cars as well. You'll be fine using it...Trust me...:P
post #57 of 74 Old 10-01-2014, 05:58 PM Thread Starter
Epictofer's Avatar
sweet, i ordered that bad boy today.
post #58 of 74 Old 10-02-2014, 05:17 AM
I run one that is shimmed and honestly I could have gotten away with running no shims. Just make sure you keep your oil topped off, that thing sucks harder than a ex porn star.
post #59 of 74 Old 10-02-2014, 08:07 AM
LW_Black4's Avatar
OEM around $300
Ahem. An OEM crank cost me 550 $CAD, so they are not cheap. This is the faster option over checking and repairing a spun bearing crank though.
Laszlo - white '11 STi sedan
LW_Black4 is offline
post #60 of 74 Old 10-02-2014, 08:10 AM
LW_Black4's Avatar
Love the sight of these $exy items!
What exact pistons have you purchased - what alloy - and are you bore-matching the cylinders for them?
