Knock Knock!! - Page 3 - Subaru WRX Forum
 33Likes
post #31 of 74 Old 09-09-2014, 10:56 AM
boo-key's Avatar
Originally Posted by AllExtinct View Post
I dont have one either. I looked into it and unless you are doing track runs and such you dont need one. Oil temp gauge will do fine.
Maybe someone else will chime in to confirm this as well.
You should have one. Subaru part# 21311AA051 for 02-07 WRX and 04-07 STI.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #32 of 74 Old 09-09-2014, 11:01 AM
AllExtinct's Avatar
AllExtinct is offline
post #33 of 74 Old 09-09-2014, 02:16 PM
No oil cooler on the 08+WRX...well that explains a lot...Way to go Toyot...I mean Subaryota...
boo-key, AllExtinct and Epictofer like this.
post #34 of 74 Old 09-09-2014, 04:51 PM Thread Starter
Epictofer's Avatar
Yea, im thinking i need to find a way to rig one up maybe. i got an old forester i could pull the cooler off that and try and make it work, but i would have to t into a coolant line somewhere
Epictofer is offline
post #35 of 74 Old 09-09-2014, 06:17 PM
boo-key's Avatar
The forester thermostat housing just might have a nipple for another outlet on it and might fit. I don't know this for sure but Its a thought.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #36 of 74 Old 09-09-2014, 07:07 PM
AllExtinct's Avatar
The bottom of the some water pumps actually have 2 ports in it one for the engine and one for the oil cooler on the other side.
I know the one that was on my old EJ205 was like that.
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
post #37 of 74 Old 09-09-2014, 07:27 PM
AllExtinct's Avatar
Here's some pics of what my spun bearing came out as well.
Not sure if yours looked as bad as this.
JDM ej205 swap.
Home state: PA Crew
Chuck.
post #38 of 74 Old 09-09-2014, 08:05 PM
He said nipple...
boo-key and Epictofer like this.
post #39 of 74 Old 09-10-2014, 08:51 AM Thread Starter
Epictofer's Avatar
Im tearing the engine down saturday. Im going to set up my gopro and take a time lapse of it coming all apart. Ill find out then how bad the damage is. There were no chunks in the oil or oil pan so thats a goodish sign lol
AllExtinct and LW_Black4 like this.
post #40 of 74 Old 09-10-2014, 02:41 PM
Again not trying to sound like a douche by any means, but make sure you follow the manual on how to correctly take the heads and block halves apart...
Epictofer likes this.
post #41 of 74 Old 09-10-2014, 03:09 PM Thread Starter
Epictofer's Avatar
oh yea, definitely going to follow tear down instructs from subaru.
this was the what it looked like when i replaced the pistons and rings!
LW_Black4 likes this.
post #42 of 74 Old 09-10-2014, 03:28 PM Thread Starter
Epictofer's Avatar
some more pictures from the first go round. Went a lil crazy with the WRB spray paint lol
post #43 of 74 Old 09-10-2014, 06:59 PM
You're missing a bolt there on the left....
LW_Black4 and Epictofer like this.
post #44 of 74 Old 09-18-2014, 09:50 AM Thread Starter
Epictofer's Avatar
Motor is torn down. Havent split the block yet, but on cyl 3 i can wiggle the connecting rod where it connects to the crank. I ordered manly pistons, h-tuff rods, and king bearings along with a killer b oil pickup and baffle. Anyone know the difference between an sti oil pump and a wrx one? they look the same but have different part numbers. Once i split the block ill see what kind of condition the crank is in, and probably have to order another one.
post #45 of 74 Old 09-18-2014, 10:51 AM
AllExtinct's Avatar
When you do crack the block don't be surprised if pressurized gas gets released. When I cracked my block a few bolts hissed at me. :-P
And just curious how many extensions you broke so far. Went through a few of them myself.
