-   -   the Infamous rebuild (http://www.wrxtuners.com/forums/f103/infamous-rebuild-32798/)
02wrxrice 07-25-2012 03:58 PM
Ill make this short and cut to the chase, i spun a rod bearing in my 2002 wrx 2.0 and now it needs either a new engine or a rebuild. I have been thinking a lot about just buying a used engine with 80k+ on it but now i am really considering just buying the short block and rebuilding it. i am a mechanic and look at all engine as the same basic prinicple with different parts so i know it will be challanging but i wanted a few peoples opinion before i made the final decision.
So, should i buy a used or build the short block and use all the parts from the old engine?
psinuse 07-25-2012 04:22 PM
Depends on your over all goals with this car. Start with a factory shortblock if your not looking into anything really serious...
02wrxrice 07-26-2012 06:47 AM
well its my daily driver right now and money is tight these days so im not exactly trying to drop 10 grand in it at the moment. thats in the near future ;)
psinuse 07-26-2012 07:21 AM
I would start with a factory shortblock then. I wouldn't worry to much about needing anything really crazy. Get your heads cleaned up and replace what needs replaced and go from there.
02wrxrice 07-26-2012 07:49 AM
okay thank you for the input. ill be ordering the short block soon in that case.
MasterP 07-27-2012 12:37 PM
I think I can't start up my own thread.. Sorry if I'm interupting but I have a 2002 wrx also and was wondering honestly what the best air intake would be for my car?? It's stocl all except for an STI exhaust
brfatal 07-27-2012 12:57 PM
As psinuse was alluding to, you could have damaged your heads as well. You will just have to tear it down to verify what all needs to be done.
psinuse 07-27-2012 03:18 PM
[quote=brfatal;283094]As psinuse was [B]alluding[/B] to, you could have damaged your heads as well. You will just have to tear it down to verify what all needs to be done.[/quote]
Quit using words I don't understand....:p
MasterP Keep the stock one until it's need. You have a long way to go before needing a air intake for your car.
