Subaru WRX Forum banner
I have a problem... Bought a used STi Shortblock
73K views 433 replies 17 participants last post by  ericwudi0830
#1 · (Edited)
The Ricer-mobile Gets Built!
So this had snowballed into an all out engine build. I'm going to maintain this thread as my build, albeit a slow process.
My goal for the car is pretty simple, make me grin uncontrollably every time I push the skinny petal.
I'll keep this first post updated as things change and try to add in an index at a later time.
For now I'll leave you with the overall build list and progress to date. I'm also going to include my costs since a lot of people underestimate the cost of big power on the Subaru platform.
If it has been purchased that's the actual price including tax/shipping/etc.
Purchased:
Block/Crank - $300.00
Machine Work - $272.46
Wiseco Pistons (100mm)/Manley Rods - $769.99
Main and Rod Bearings - ACL Race Std. Size - $138.83
OEM Gasket Kit/Case Bolts - $254.07
P&L High Flow Pump - $319.49
ARP Head Studs - $162.94
Gates Timing Belt/OEM Tensioner/Gates Water Pump/All Cogs/Pulleys - $289.97
Rota Torque 5x100 - 17x8 et48 - $300.00
Dunlop Direzza Z1 Sport Star Specs 235/40/17 - $673.94
These are all budgeted prices below
Next Up:
Dome Coating on Pistons - $125.00
Group N Engine Mounts (need four nuts for plates) - $135.00
Injectors - 1000cc ID's w/pigtails - $427.50
Deatschwerks 300lph Fuel Pump w/install kit - $170.00
Cast Turbo Inlet - Brand TBD - $250.00
KS Tech Big MAF CAI - 73mm - $230.00
Brian Crower Valve Springs/Ti Retainers - $204.25
Supertech Valve Guides and Seals - $114.98
Brian Crower Stage II Cams - $586.00
Killer B Optimal Oil Pan & Ultimate Pickup & Baffle - $689.48
FMIC Brand TBD- $800
Carbonetic Pro-Blade Clutch/Fly ABS23132-16 - $1,349.00
Blouch dom3xt-r (not sure new or used) - $1,200.00-$1,800
Heads - MA Stage III or EQ Stage II Head Job -$950.00
Valves - Not sure on brand or size. Looking at ferrera, supertech. Std or +1mm. Not sure yet.
INDEX:
Main Bearings: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index2.html#post254384
Oil Pump, Rods, Pistons, Rod Bearings: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index2.html#post254902
ARP Head Studs: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index3.html#post256378
Master Gasket Kit: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index3.html#post256884
Teaser of the New Wheels: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index4.html#post257136
New Tires: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index4.html#post257290
Block Back from Machine Shop: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index4.html#post257475
See less See more
#199 ·
Got the hood last night, put it on tonight.
Forgot to take the camera out of manual focus so all the on the car shots turned out blurry and it's now too dark so I'll get some tomorrow.
Hood looks great in person, very high quality piece. I don't, however, like the way it makes the car look right now. It'll be fine once it's painted but holy hell I hate bare carbon.
#201 ·
What color are you going with on the carbon fiber hood? Now I know that at least on my model year the carbon fiber hood weights only like 2-3 lbs less than the factory hood, not sure about the newer model like yours....
#202 ·
08+ WRX got steel hoods that weigh 45 lbs. CF weighs about 25 so I'm almost cutting it in half.
Getting it matched to the car... Really debating if I'll paint the whole thing or paint it all silver but keep the vents in cf as an accent.
I'm going to get a pic up tonight and see if the photoshop thread on Nasioc will do some magic for me.
#222 ·
Yeah, the sutle CF look is something that most people don't do on the hood. Something different makes it unique...unique looks good. It shows creativity and imagination.
#224 ·
i called people retards after they couldnt read a post and some mod said ive been waiting to get you! and gave me 1 point. i called him a winner and Unabomber gave me 20 points and a time out, so ### over there!!
here ya go
