The Ricer-mobile Gets Built!
So this had snowballed into an all out engine build. I'm going to maintain this thread as my build, albeit a slow process.
My goal for the car is pretty simple, make me grin uncontrollably every time I push the skinny petal.
I'll keep this first post updated as things change and try to add in an index at a later time.
For now I'll leave you with the overall build list and progress to date. I'm also going to include my costs since a lot of people underestimate the cost of big power on the Subaru platform.
If it has been purchased that's the actual price including tax/shipping/etc.
Purchased:
Block/Crank - $300.00
Machine Work - $272.46
Wiseco Pistons (100mm)/Manley Rods - $769.99
Main and Rod Bearings - ACL Race Std. Size - $138.83
OEM Gasket Kit/Case Bolts - $254.07
P&L High Flow Pump - $319.49
ARP Head Studs - $162.94
Gates Timing Belt/OEM Tensioner/Gates Water Pump/All Cogs/Pulleys - $289.97
Rota Torque 5x100 - 17x8 et48 - $300.00
Dunlop Direzza Z1 Sport Star Specs 235/40/17 - $673.94
These are all budgeted prices below
Next Up:
Dome Coating on Pistons - $125.00
Group N Engine Mounts (need four nuts for plates) - $135.00
Injectors - 1000cc ID's w/pigtails - $427.50
Deatschwerks 300lph Fuel Pump w/install kit - $170.00
Cast Turbo Inlet - Brand TBD - $250.00
KS Tech Big MAF CAI - 73mm - $230.00
Brian Crower Valve Springs/Ti Retainers - $204.25
Supertech Valve Guides and Seals - $114.98
Brian Crower Stage II Cams - $586.00
Killer B Optimal Oil Pan & Ultimate Pickup & Baffle - $689.48
FMIC Brand TBD- $800
Carbonetic Pro-Blade Clutch/Fly ABS23132-16 - $1,349.00
Blouch dom3xt-r (not sure new or used) - $1,200.00-$1,800
Heads - MA Stage III or EQ Stage II Head Job -$950.00
Valves - Not sure on brand or size. Looking at ferrera, supertech. Std or +1mm. Not sure yet.
INDEX:
Main Bearings: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index2.html#post254384
Oil Pump, Rods, Pistons, Rod Bearings: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index2.html#post254902
ARP Head Studs: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index3.html#post256378
Master Gasket Kit: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index3.html#post256884
Teaser of the New Wheels: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index4.html#post257136
New Tires: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index4.html#post257290
Block Back from Machine Shop: http://www.wrxtuners.com/forums/f10...d-sti-shortblock-29055/index4.html#post257475
Purchased:
Next Up:
INDEX:
