Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Cylinder Head & Short Block
Old 12-19-2008, 06:25 PM   #1 (permalink)
04paulieWRX's Avatar
Car: 04 WRX
Reputation: 04paulieWRX is an unknown
hybrid question
i always thought then when you build a hybrid, the final displacement was 2.5L. but as i was reading around, i saw places where it said that it was only 2.1 or 2.2 liters. Could someone clear this up for me
Old 12-19-2008, 06:29 PM   #2 (permalink)
That is not true. Those are stroker kits for the 2.0L that give you that final displacement. A hybrid uses the physical block and pistons out of the larger 2.5L engine so it gives the same displacement, you just keep your heads. Heads don't really effect displacement much. I am drastically over-simplifying but hopefully that helps.
16G powered lagless fun
Old 12-19-2008, 06:39 PM   #3 (permalink)
Car: 04 WRX
it does, thanks
