Hybrid engine part break down??? - Subaru WRX Forum
post #1 of 4 Old 08-09-2009, 03:03 PM Thread Starter
Thumbs up Hybrid engine part break down???
OK so i bought a 04 wrx with 55k on it, all stock...... i have had the car for 1 month. Well on the way home form work i started to hear rod knock!Cry!, i was driving 65mph in 5ht gear and it started so i have no idea what went wrong.... i am about to pull the block and figure out what went wrong. Since the engine is going to be out and most likely going to need a new block i was wondering exactly what i needed to do the hybrid engine set up, for now i want to get it running and nothing to crazy. my goals are to eventually get to 350whp so nothing too crazy.... what exactly will i need to get my car runnig with the hybrid engine?? and any suggestions on getting to 350whp will be appreciated..... i have read on here about hybride engines but i haven't seen a full part break down on what i need...
Thanks guys
koa2bkrb is offline
post #2 of 4 Old 08-09-2009, 04:10 PM
Heres one of the members build/breakdown of most everything with some good links, pics and all. Hope this helps some.
post #3 of 4 Old 08-09-2009, 05:36 PM
I don't know if you tried to post mine or another, but here's mine. Hybrid build/rebuild info
You just need the STi bottom end, STi 565cc injectors, an STi TMIC and Turbo, and probably a Walbro 255 fuel pump. I'm pretty sure all odds and ends beside that are talked about in the link. I would do forged pistons as well, since you only have to do wrist pins to get to them with a bare block.
post #4 of 4 Old 08-09-2009, 05:55 PM
Chase I did try posting yours, sorry that it didnt work, didnt even check. Thanks for that and sharing your experiences.
