Help with the Valves/valve train - Subaru WRX Forum
post #1 of 26 Old 08-15-2006, 07:35 PM Thread Starter
brokenarrow is an unknown
OK I just need some information about this..
1- I am getting a kelford cam ( the drag one, I can get the Specs if needed).
and a upgraded valvetrain kit with dual springs.. AND 1mm bigger valves..( IF I can find them!!..
Q- will I have any problems With lash or ANYTHING ...I am gonna have a machine shop do the install, SO I should be fine ....RIGHT??...the SHOP should know how to clearence them ...RIGHT???
BUT I dont want to get it put ALLLLL back together and FIND out a I have a LOUD tick and have to take it apart again
thanks!
OH and where can I get a fair priced 1mm over valve kit.
ALSO ...does anyone know the spec's on a stock valve.??
This is the spec's of the valves I was looking at... ( I dont know if thay are any bigger than stock or not.....keep in mind I am looking for 1mm bigger valves!)
Intake Valve
Head Diam: 36.50mm
Stem Diam: 5.96mm
Length: 104.35mm
Exhaust Valve
Head Diam: 32.50mm
Stem Diam: 5.96mm
Length: 104.70mm
brokenarrow is offline
post #2 of 26 Old 08-15-2006, 08:21 PM
Axis Power Racing offers what you asking for.. I also have Kelford Cams and Over sized Valves. I also increased my lift for more flow...
post #3 of 26 Old 08-15-2006, 08:40 PM
I hope that helps.. Sorry if I missed anything, I'm tired of reading that manual..
post #4 of 26 Old 08-15-2006, 08:46 PM Thread Starter
Yes, Thank you.
Now I know if the SHop screws up, I can fix it myself, without too many problems.
BUT I am still wondering if the specs on the valves I listed in the 1st post are bigger or stock size..I wasnt able to tell from your post..
thanks alot You have been MOST helpfull!!!
EDIT: I got it .. They are the STOCK specs that I have posted.
post #5 of 26 Old 08-15-2006, 09:02 PM
Sorry, I didn't see that.. Shoot Ron - R.Williams@axispowerracing.net and email, he will hook you up with all the info you want..
post #6 of 26 Old 08-15-2006, 09:13 PM Thread Starter
Thank you
post #7 of 26 Old 08-16-2006, 08:51 PM
1mm "Big STI Valves".. only $1,599.... !Cry!
http://www.xcceleration.com/engine-p...ceengines.html
post #8 of 26 Old 08-17-2006, 12:09 AM Thread Starter
ahahahah.... no way!. I found some here at slowboy http://www.slowboyracing.com/more.ph...4&mods=21-8845
BUT NEW BIG question..
will I need to get new buckets for my new drag camshaft..???
and if so WHERE THE HELL do i get em from ..!!!!????????????
thanks
post #9 of 26 Old 08-18-2006, 05:02 PM
First off, you need "16" valves.. "8" Intake & "8" Exhaust Valves...
Ok, you don't need new buckets, just new shims for the proper thickness to properly set the tolerances for the new cams.. I actually already posted the chart with the thicknesses and part numbers.. Some guys will do the "Conversion" to put the shims under the buckets, I have this done on mine but i don't know where you can get those buckets, as Ron @ Axis did my head work for me and it was part of the package...
post #10 of 26 Old 08-19-2006, 01:27 AM Thread Starter
my buckets are shimless ..I think all o4 and up are ... SO I still can shimm them???
and good lookin out ..I didnt catch that ( only 8 valves).. I would have bought them and flipped out when I got only 8 ..ehheh... SOOO back to searchin for the 16 1mm over valves....
post #11 of 26 Old 08-19-2006, 09:34 AM
I "Assume" you have to buy "8" Exhaust and then "8" Intake valves.. Then you can alter the sizes.. As for the "Shim-less" buckets, I assume you will then need to purchase "New" buckets UNLESS the conversion that I have is "shim-less" buckets with Shims underneath them.. Again, I don't know what all was done there as I didn't do it..
post #12 of 26 Old 08-20-2006, 03:05 AM Thread Starter
Cool.. I guess ill just leave it to the machine shop to figure out.
If I need new buckets, he can get em ..
BUT on a different note.. I applied for a 2nd job today.HAHAH.. I want my race car bad!!!!!
AND thanks for all of your help.!!
I am sure Ill need it again!
post #13 of 26 Old 09-04-2006, 05:16 PM Thread Starter
OK I need the help again!
I need to know what camshaft to go with .
I want a cam that makes the car lope a little. ( gotta love the v8 lope)
I want the cam to have power to 8000 RPM's
any idea's on the specs I should be looking for,
I DONT want to idle at 2k RPMS just to keep the car running.
I dont mind running at say 1k
so shoot some spec's my way please.
thanks guys
post #14 of 26 Old 09-05-2006, 05:33 PM
LOL. you want it all. Low Idle and lumpy profile.. The two really don't go together well in a REX.. My idle is about 1500rpm and it definitely surges a little as the vacuum was totally crushed by my cams.. I love my cams however, nice power with my GT35R..
post #15 of 26 Old 09-06-2006, 09:28 PM Thread Starter
well I got MOST of my parts on the way..
This is getting closer to being done. ........ I said CLOSER ... I still have a little way's to go.
I got :
-CP pistons w/rings (stock bore and 9:5:1 and wrist pins
-Eagle H rods w/ ARP studs
-SuperTech dual valve spring valve train w/ ti. retainers
-Kelford AVCS camshafts ( 278 &274) from cosworth..check it out!!.......>
-Cosworth main and rod bearing
- Cosworth oil pump
-OEM gaskets
-1mm over SuperTech Valves
-ARP head studs
- Gauges = wideband o2/ EGT/ fuel pressure / OIL pressure/ oil temp/ boost/ narrow band o2
- T-70 Turbo
-46mm EWG
- Oil cooler
- exhaust wrap
NEED:
- Injectors
- fuel pump
- AFPR
- and clutch
- water injection
So if anyone has anythign for me ........HIT ME UP!!!
