Go Back   WRX Forums > WRX Tech Forums > Cylinder Head & Short Block
» Sponsor Links
»Garage Storage and Cabinets
Old 07-05-2008, 04:50 AM   #1 (permalink)
JohnWRX's Avatar
Reputation: JohnWRX is an unknown
Engine rebuild
Hello to all,
my WRX 2002 engine have problems then it's was thinking it's time for a rebuild.
I d'nt' want an EJ25, would like to rebuild mine.
With a budget of 2000-3000$ what can i do and where can i buy the pieces?
I was thinking:
pistons wiseco/cosworth (will my open deck support 92.5mm? )
rods cosworth/carillo
hp oil pump
for head gasket i don't know 0.78 or 1.1 or 1.5 mm?????
ARp or cosworth head studs
Really confused about it
thank to all for help
G
WRX blue
Old 07-05-2008, 04:05 PM   #2 (permalink)
tom_noland's Avatar
Reputation: tom_noland is an unknown
Send a message via AIM to tom_noland Send a message via Yahoo to tom_noland
Impreza Engine
This should get you on your way.
Tom
'05 WRX Wagon (RIP)
Cobb AP Stg 2
RIP baby....Here I come STi.
Stupid deer.
Old 07-06-2008, 01:34 AM   #3 (permalink)
Just like Tom did, search around, the 2.0 has been built up, rebuilt, made into a hybrid, all with great results when done right. Good luck with your build/rebuild.
"Stage 2, not so cool anymore, starting to get bored now."
Old 07-06-2008, 03:25 AM   #4 (permalink)
JohnWRX's Avatar
I've search around, and i'v found that the most have done a 2.5 l, the one i don't want.
Because i live in Switzerland and i can have problems if they see EJ25 and not a EJ20.
Gruppe-s have only 2.5 l shortblock.
I was asking myself what i need for a good rebuild, what pieces...
Thanks
WRX blue
Old 07-06-2008, 12:08 PM   #5 (permalink)
buy an sti crank, rods and bigger pistons . bore you 2.0 out to a 2.2.
Old 07-06-2008, 01:08 PM   #6 (permalink)
JohnWRX's Avatar
I was thinking the same, put inside a stroker kit 2.2l Cosworth, but somebody told me that if i bore for that,the walls of the cylinders of my open deck will be thinner and it's dangerous if i go up with the pressure or at high temp.
92mm and 92.5mm what is the diffrence in power and torque?if there is....
What kind of headgasket i need? 0.78, 1.1, 1.3 or..?
thanks again
WRX blue
