Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Cylinder Head & Short Block
Old 01-05-2008, 05:46 PM   #1 (permalink)
gt420hp's Avatar
Car: 2006 EVO MR IX
Reputation: gt420hp is an unknown
Engine rebuild 2004 WRX
My son's 2004 WRX (automatic) broke a rod with only 59,000 miles on the car. Look like number 1 rod, and crankshaft are crap....possibly block is damaged from the rod breaking too.
Where can I find a good used 2.0l engine to replace it? Or would it be better to buy a new block and add better internals? Would a stroker kit make sense?
Car is OEM stock except for Perrin exhaust system.
[webpage] [posts] Reply With Quote
Old 01-05-2008, 07:01 PM   #2 (permalink)
GoWRXGo's Avatar
Car: 04 WRX
Club Region: Southeast
Reputation: GoWRXGo is an unknown
Send a message via AIM to GoWRXGo Send a message via Yahoo to GoWRXGo
well at this point you have a crossroads infront of you IMO. Do you want to go back with a US Spec 2.0L block?? Or since your halfway there already, switch over to a JDM Spec 2.0L
or a US Spec STi Block and Tranny? Personally, I would go for the STi Block and Trans. swap, but thats just me and I dont know anyones financial situation.
Old 01-05-2008, 07:08 PM   #3 (permalink)
wrxman420's Avatar
Reputation: wrxman420 is more helpful than not
As long as it's broke i'd go with a usdm sti 2.5l shortblock. They go for between 1500-2000. JDM motors are nice, but they are also pricey.
Old 01-05-2008, 07:30 PM   #4 (permalink)
GoWRXGo's Avatar
Car: 04 WRX
+1 to the pricey JDM blocks! I would love to have the EJ207, but $9k....I mean, Im sure its super sweet...SUPER SWEET...but, thats still $9K.
Old 01-05-2008, 11:21 PM   #5 (permalink)
MilesFox's Avatar
Car: 87 RX, 95 Legacy, 88 sedan 4wd conversion
Reputation: MilesFox is an unknown
swap in a 2.2 from a pre95 legacy
Old 01-06-2008, 07:09 AM   #6 (permalink)
SWFL Scooby's Avatar
Reputation: SWFL Scooby is an unknown
+1 to the 2.5l block, stock internals unless you have budget to upgrade pistons, etc. Stroker kit not needed though..
D-Rock
Under constant pressure
Old 01-06-2008, 10:57 AM   #7 (permalink)
the block should be fine, you may just need to resleve the cylinder that the rod broke in. I'd do a 2.2 stroker, with and sti crank and rods.
Old 01-06-2008, 12:36 PM   #8 (permalink)
b7g
b7g's Avatar
Reputation: b7g is an unknown
Agree... This might be the most cost efficient way to go if you are not affraid of the rebuilding work.
Also, check out these guys. They can source jdm parts for relatively cheaper than others.
You have to emial them or call for a faster responce: JDMSPECC4U.COM -- USED JDM STI PARTS AND ACCESSORIES
drive = freedom
