Engine Knock - Subaru WRX Forum
post #1 of 15 Old 02-22-2009, 12:12 AM Thread Starter
kil0shady is an unknown
Engine Knock
I need a second opinion on a motor knock. I ran my car at the track and it ran great. On my way home my check engine light went on so i pulled over and checked it out. Was pulling a bank 1 is running to lean so i got it home and turned it off. In the morning I turned it over and a horrible knock came from the motor. It sounded like I threw a rod bearing. Not sure though, any input?
EJ20 with fp green, 800cc injectors, protuned, FMIC, Arp head studs, Crower valve train, light weight pully, flywheel, new timing belt.
kil0shady is offline
post #2 of 15 Old 02-22-2009, 09:19 AM
VD5505's Avatar
drain the oil and look at the oil really colse, you can drain the oil through a old white T shirt and that will catch to see if you have any metal in the oil, and also take all your plugs out and look at them and if you can do a compression test
VD5505 is offline
post #3 of 15 Old 02-22-2009, 09:21 AM
what exactly did the knock sound like...and where was it coming from
post #4 of 15 Old 02-22-2009, 10:52 AM Thread Starter
just a very loud consistent knock coming from the engine
post #5 of 15 Old 02-22-2009, 10:53 AM
VD5505's Avatar
did your check engine light ever flash?
VD5505 is offline
post #6 of 15 Old 02-22-2009, 11:04 AM
sounds like its time to tear it apart.
nagyhead is offline
post #7 of 15 Old 02-22-2009, 12:25 PM Thread Starter
yeah for a little it did
post #8 of 15 Old 02-22-2009, 12:57 PM
VD5505's Avatar
well like dumdum said i think its time to rip your engine down did you ever do a compression check for the heck of it?
VD5505 is offline
post #9 of 15 Old 02-23-2009, 02:09 PM
Originally Posted by VD5505 View Post
well like dumdum said....
Heh, its semantics. Nagy is not dumdum...though his rep bar is getting quite close.
post #10 of 15 Old 02-23-2009, 04:00 PM
VD5505's Avatar
Shoot my bad i ment to say Nagyhead i saw the red print and just thought of DumDum sorry about that nagyhead
VD5505 is offline
post #11 of 15 Old 02-23-2009, 06:12 PM
its cool, at least you confused me with someone who knows his shit!!
nagyhead is offline
post #12 of 15 Old 02-23-2009, 10:43 PM
wrxshotta's Avatar
wrxshotta is on thin ice
loll nagy/dum dum...both know there stuff
wrxshotta is offline
post #13 of 15 Old 02-23-2009, 11:12 PM
moscstupido is an unknown
sounds like you could have blown your piston rings which would cause permanant piston slap
I for one harvest the power of E
moscstupido is offline
post #14 of 15 Old 02-24-2009, 06:05 AM
Every pull the injectors? Friend had an issue and sounded like a lite knock and turned out to be 2 of his injectors were clogged (bright sided way to look at it)
post #15 of 15 Old 02-25-2009, 07:21 AM
zmanoside's Avatar
zmanoside is a helpful contributing member
Well, it looks like what was needed to be said was said...what did you run at the track lol??
12.7 @ 109
zmanoside is offline
