-   -   EJ20 open deck block (http://www.wrxtuners.com/forums/f103/ej20-open-deck-block-10057/)
knot04 12-15-2005 07:00 PM
a while ago, there were a few threads regaurding the strength of the EJ20 block. on a daily driver basis, can the factory open deck EJ20 take 350-375 AWHP? this would be attainable with a 2.2l stroker kit, FP Green or Deadbolt 20G turbo, and would only need an RA gear set in the trans. at 350 AWHP the car would be a force to recon with on the street, yet still very "streetable."
any thoughts? thye idea of spending the money on a motor swap is VERY un-apealing to me.
imbeterthanu 12-15-2005 07:24 PM
350awhp on stock internals no. it might last for about a week. but with the stroker kit yeah u should have problems with that. even with a FP green you should be able to produce more power then 350 whp.
knot04 12-15-2005 08:29 PM
[QUOTE=imbeterthanu]350awhp on stock internals no. it might last for about a week. but with the stroker kit yeah u should have problems with that. even with a FP green you should be able to produce more power then 350 whp.[/QUOTE]
so the block wont hold it? the stroker kit will take care of all the internals, and i dont see any issues with the heads, just the block.
imbeterthanu 12-15-2005 09:56 PM
i dont see any reason why the block wount hold.
nick4592 01-04-2006 05:34 PM
The Ej20 will hold 350whp easily...I am doing it right now with all stock internals on 18psi with 91 octane and 22psi with 110 octane
WRXtreme 01-04-2006 06:49 PM
A friend of mine was running about 325whp on his stock block w/ a PE1820. His weak point was the trans, which he replaced with a STi 6-speed.
sneakyracer 05-31-2007 10:30 PM
the ej 205 its much stronger than people think , the key its the tuning , for instance ive seen sotckers with big turbos and all the supporting mods hitting close to 400whp and passing that mark (dyno jet) on race gas , what breaks easy is the tranny. my car for instance has the ej 205 w pistons and rods , all valve train stock ,big turbo , massive gadiel tuning , and all the supporting mods, its a day driver with 411whp and a night warrior with race fuel 508 whp . so dont under estimate the open deck , I havent and im having a blast for a year now with this power level, before thet withthe other set up my whp on pump was 360 and on race 437whp , remem ber no NOS.
mosc 06-01-2007 11:45 AM
you're going to break RA gears LONG before the EJ20 dies.
sneakyracer 06-01-2007 09:22 PM
true ... my ra sti (longer than ra ratios)broke @437whp, love the strenght of the 6 speed , but miss the gear ratios of the 5 speed
mxboy15u 06-03-2007 06:44 PM
A STI shortblock is cheaper than what you want to do...$1700
imbeterthanu 06-09-2007 12:56 AM
die thread die:beatentod :beatentod :beatentod
