-   -   EASIEST way to remove heads (http://www.wrxtuners.com/forums/f103/easiest-way-remove-heads-13244/)
skate enjoi 07-11-2006 10:55 AM
what is the EASIEST way to remove the heads???? any help would be greatly appreciated...
imbeterthanu 07-11-2006 11:58 AM
the easiest was would probably be rrmoving the motor. its a real tight spot.
skate enjoi 07-11-2006 12:01 PM
[QUOTE=imbeterthanu]the easiest was would probably be rrmoving the motor. its a real tight spot.[/QUOTE]
i already have the motor out, forgot to mention that.... but is it just unbolt the intake manifold and fuel rails, unbolt header, then unbol tthe heads? can the heads slide out after that or is there something else you have to do???
9d2TSi 07-11-2006 01:21 PM
Do you have the FSM? I can make you a copy of it and mail it to you if you want. PM me.
skate enjoi 07-11-2006 01:41 PM
FSM??? i got some manual cd that i bought of ebay that has covered everything i had questions about i just cant find anything about taking the heads off.... i guess ill just try my way and see what happens.....unless there is an easier way??? (assuming my way will actually work)
9d2TSi 07-11-2006 01:52 PM
FSM = Factory Service Manuals.
Since you have the same thing that I've got, I guess you're straight. !Laugh!
skate enjoi 07-11-2006 02:03 PM
straight as a circle as far as having the information...... i still cant find it.... do i just unbolt the intake manifold, fuel rails, exhaust manifold, then unbolt the head from the block.... can the heads slide out then or no????
or do i actually have to take the entire intake manifold off the car???---i hope not
imbeterthanu 07-12-2006 09:07 AM
any thing thats bolted to the head needs to come off. and make sure u time it. it makes it easyier reinstalling it.
stileguy 07-13-2006 10:38 AM
remove in this order and you should get it...
headers,intake as a whole unit, crossover water pipe, plastic cam covers, cam sprockets, rest of plastic cam covers, valve covers, cams and remember to mark the buckets with their positions as they are clearanced for that specific position, head bolts, heads will come off now with a soft hammer and some light force.
hope this helps
skate enjoi 07-13-2006 12:49 PM
cool see that is what ive been looking for... i pretty much figured it out by now... but thanks! i do have one more question... my brother managed to strip a head bolt when i was working on the other side... is there any way to get it out???
stileguy 07-14-2006 11:30 AM
in short you're f@#ked, will need major surgery, go to tool shop and get a stud remover tool, like a small plumbers wrench, hate to be you!!
skate enjoi 07-15-2006 11:38 PM
dont worry... i got it out after pounding a smaller size socket onto it... no major surgery at all... came right off after that stud was removed....
JiveMasterT 07-15-2006 11:50 PM
[QUOTE=skate enjoi]what is the EASIEST way to remove the heads???? [B]any [/B]help would be greatly appreciated...[/QUOTE]
[IMG]http://www.sdnl.nl/images/guillotine.gif[/IMG]
...seriously though... glad you got it.
skate enjoi 07-17-2006 07:33 AM
haha that was next on the list......
stileguy 07-20-2006 11:05 AM
i would be removing your brothers head!:beatentod
