Cams cams cams cams - Page 2 - Subaru WRX Forum
post #16 of 25 Old 12-05-2012, 03:13 PM Thread Starter
2.5L and 2.0L cams have different centerlines. I think the of set is 15 degrees if memory serves me right.
post #17 of 25 Old 12-07-2012, 02:34 PM
Delta customs are usually a bit more than what you can get off the shelf from Kelford or Gsc, something around $1,000-1,200 for a set. Kelford will do custom grinds too though, I don't think they charge extra for it either.
I don't have experience but I'm sticking with GSC Stage I's for mine. Stock turbo will be used after I get done building the engine, but I figure I'll go the rotated GT30 sized setup or Dom 1.5/2.5 sized turbo... Somewhere around 50 lb/min.
In your case, GT35 size with a 9k redline I would want it to breathe more up top and would get a little more lift, while keeping it around 272 duration. I don't know that your heads are holding you back as much as the turbo right now. Just about every other 20g falls off at that 6,000-6,500 area, even on 2.5's. The best would be upping the turbo now and seeing where the power is made at, then changing out the cams.
post #18 of 25 Old 12-07-2012, 03:22 PM Thread Starter
They are stock unported 2.0L heads. I looked into a GT35 to add to the mix, but currently my budget just isn't allowing much. I was told Delta Cam were only around $600 or so for custom regrinds... $1000 for regrinds.
post #19 of 25 Old 12-07-2012, 07:30 PM
^Regrinds are about that much, I was referring to a custom set of new cams.
Unported 2.0L heads dont' flow as bad as you think. They're definitely not the root of the power falling off at 6400. I'd say #1 is the size of the turbo, #2 is cams, #3 head ports/valves.
If I could guess if you get head work and cams the power will still fall off pretty hard by 7k. You'll make more than a stock sti at that level, but it's still falling hard from peak.
post #20 of 25 Old 12-08-2012, 05:17 AM Thread Starter
I was referring to custom regrinds costing that much. I'm thinking of doing just a complete upgrade turbo, ported heads and cams. I know the heads aren't the biggest issue with power, although ported heads with the right cams will give a major increase in power, but planning ahead is better than having to pull the motor twice.
For the record I'm making more power than even a modified STi...
post #21 of 25 Old 12-10-2012, 08:24 AM
I call BS.... You're not even into the 10's and you have a 20g. Stock turbo STi's are faster.
post #22 of 25 Old 12-10-2012, 10:47 AM
Sounds like a challenge... lol
post #23 of 25 Old 12-10-2012, 02:41 PM Thread Starter
Sarcasm?
post #24 of 25 Old 12-11-2012, 05:57 AM
I'm thinking so Keith. He never puts up emoticons.... He lacks what we would call "the social skill".
What movie is that from?
post #25 of 25 Old 12-11-2012, 02:58 PM Thread Starter
Don't know. I guess I should state for the record that I am making more than some modified STi's. Other than vf52 equipped ones running 11's..
