Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Cylinder Head & Short Block
Old 08-21-2005, 08:13 PM   #1 (permalink)
Trader Rating: (3)
Cam Gear removal...
Ok guys, I did a search and I found nothing so here is my question.. As you all know my luck my rex is down.. I pulled the motor today to get to the root of the problem, or atleast find the root of my problem.. Well, as my luck goes I can't get the cam gears off to pull the cams so I can pull the heads... I assume they are standard thread as the crank pulley was, but no luck.. Non on reverse thread either.. I tried an impact first, then a wrench on the hex in the cam and a pipe on an allen wrench, yea, I am no small boy and I couldn't budge it.. I don't want to apply heat, but unless I am missing something I don't see any other options.. Some help would be greatly accepted.. Thanks guys...
Old 08-23-2005, 04:18 PM   #2 (permalink)
Trader Rating: (3)
Well no one even posted here, but I fingured it out anyway.. I found it easy once I noticed that there was a 1-1/8" hex pattern on the cam shaft.. I simply put a wrench on that and a Pipe on the allen wrench and with a lot of elbow grease the Cam Gears came off.. I will say this.. They are tight....
Old 08-24-2005, 05:55 PM   #3 (permalink)
imbeterthanu's Avatar
Car: 05 WRX
Reputation: imbeterthanu is an unknown
just out of curiousty. what do they torque down too?
Old 10-22-2005, 03:35 AM   #4 (permalink)
stileguy's Avatar
Reputation: stileguy is an unknown
an easier way to remove the cam gears is to remove the cam covers and put a wrench on the flats on the cam shaft. bit late i guess, maybe it'll help someone else.
Old 12-16-2005, 04:46 PM   #5 (permalink)
Trader Rating: (3)
Sorry imbeterthanu I just now realized that there were replies to this post.. Once I was able to remove the Gears I didn't check back.. Well to answer your question the manual says 72.4 ft lbs but man I will tell you that they were tighter than that...
« Ej207 | Stroker Kit »
