Go Back   WRX Forums > WRX Tech Forums > Cylinder Head & Short Block
» Sponsor Links
»Garage Storage and Cabinets
Old 09-30-2008, 12:46 AM   #1 (permalink)
Reputation: AWD_JOE is an unknown
built ej205
Im thinking about building my 2.0. Does any one know of someone doing this. I can get a set of cp pistons and a set of BC rods for cheap. I have been looking all over the net looking for some one that has built a EJ205. I have also looked at the 2.5 swap, but i never really seen a built 2.0. i guess these rods can handle 600hp. would a 2.0 crank hold that? i can build my 2.0 for the price of a 2.5 bottom end. just not sure what way to go. I know people are going to say the 2.5 will spool a turbo faster...i can get the pistons and rods for $600 and bc 272 cams for $400..... and i have the trans coverd...i just bought a Kazz gear set.......any one have links or somthing on a built 2.0 usdm version.. thanks!
Old 09-30-2008, 09:35 AM   #2 (permalink)
BugEyedAWD's Avatar
Club Region: Southeast
Reputation: BugEyedAWD is on thin ice
Send a message via MSN to BugEyedAWD
Welcome to Fastech Motorsports
the guy that owns that shop/Bugeye is supposed to be the 3rd fastest wrx in the world. (from what people say around here, but i doubt it.) just go to that page, click on services, OR give them a call in the evening and ask questions. From what i know, he uses a hybrid build but he can give you alot of really good advice as far as building your engine.
Old 09-30-2008, 11:20 AM   #3 (permalink)
Not sure how much effort you have put into looking but it's been done a ton of times on NASIOC and I-club.The WRX has been in the states longer than the STi.The 2.5L block wasn't even an option for a couple of years.I would have to search just like you to find the links...
Aarg matey!
ECU Pirated by RomRaider
Old 09-30-2008, 11:33 AM   #4 (permalink)
BugEyedAWD's Avatar
^ now that you mention it, i had a guy contact me on NASIOC about 7 months ago trying to sell me engine work on my motor. So i would imagine that would be a better bet as far as gathering information.
Too, you can find build kits on the brian crower website. Although i should have said this earlier. but thats just a prime example of what drinking on a week night will do to you. forgetfulness and slow to think .
Old 09-30-2008, 04:28 PM   #5 (permalink)
You're better off starting with a used EJ207 from Japan if you want a well built 2.0L...
Engineers can't spell, sorry!
Online
Old 09-30-2008, 04:54 PM   #6 (permalink)
wrxman420's Avatar
Reputation: wrxman420 is more helpful than not
+1 for factory forged internals and they rev higher. Either way good luck with the build, your going to need it with a Kazz gearset (I hear they are as good as stock and RA gears)
Old 09-30-2008, 11:04 PM   #7 (permalink)
Reputation: turmic is known to be trustworthy and helpful turmic is known to be trustworthy and helpful
Mosc, that's exactly what I was thinking. But, I have one question to that...because I believe at least one member on these boards did a EJ207 swap. I think he had to change his ecu though. Would that be necessary?
Old 09-30-2008, 11:42 PM   #8 (permalink)
yes, definitely.
Online
Old 10-04-2008, 04:50 PM   #9 (permalink)
[quote=wrxman420;206010Kazz gearset (I hear they are as good as stock and RA gears)[/QUOTE]
Where did you here that from lol. They can handle 500whp there stright cut lol i know some one personally that has a 35r and runs thoes gears......well maybe ther are diff kinds of gears kazz makes. But the ones I have they are alot beefyer than stock and ther stright cut.
Any ways thanks for the info guys
Old 10-28-2008, 10:31 PM   #10 (permalink)
Reputation: IAMROGER is on thin ice
ok look guys the best build out there is the ej25 with 2.0 heads but you have to run arp head studs and a 101mm head gasket
there are no issue's with is built trust ive been running with it for a while and with just a stock turbo and maybe a few bolt ons i could bark the tires into fourth gear so
if you dont trust anyone or cant find anything i might be able to help
