Building the Motor - Subaru WRX Forum
post #1 of 23 Old 01-15-2007, 10:34 AM Thread Starter
purplehaze is an unknown
Building the Motor
for the 06 WRX with 2.5L, at what horsepower level do I need to consider building the motor?
Currently running perrin dp, HKS exhaust APS top mount IC and K&N typhoon with Ecutek reflash at 302 whp. I am upgrading the clutch next, but was planning on saving to build the motor prior to new turbo and FMIC and fuel upgrades......good idea?
purplehaze is offline
post #2 of 23 Old 01-15-2007, 03:14 PM
ohhNOwrx's Avatar
ohhNOwrx is an unknown
I would think about building the tranny first that build the motor. Get some gears or go for sti tranny but i think geting gears is cheaper and better.
ohhNOwrx is offline
post #3 of 23 Old 01-15-2007, 03:52 PM
dont upgrade the clutch unless you upgrade gearsets.
WRXKidid775 is offline
post #4 of 23 Old 01-16-2007, 06:51 AM
Jakes02 is an unknown
upgrade gears or go with a 6-speed.
Jakes02 is offline
post #5 of 23 Old 01-16-2007, 08:35 AM
Speedogomer's Avatar
Speedogomer is an unknown
Send a message via AIM to Speedogomer
Wait, 302whp on a stock turbo?
Do you have an STI?
-Justin, aka Gomer
(sold)-05 WRX
(new)-04 Cadillac CTS-V
Speedogomer is offline
post #6 of 23 Old 01-16-2007, 10:23 AM
koolpaul1082 is an unknown
previous statements are exactly correct, motor work should be the last thing on your list to invest in. i would go turbo first/supporting fuel mods. then suspension or brake mods, then save for tranny work/ clutch&drivetrain. and last motor work, because as stated many times before our engines being 2.0 or 2.5 tend to be the strongest point of our cars.
koolpaul1082 is offline
post #7 of 23 Old 01-16-2007, 05:40 PM
if you wanted to go big with your turbo id go like this:
em
suspension
brakes
transmission
save
save
save
save
save
engine, turbo, supporting mods and fuel all at once so you dont buy a turbo and injectors then go through everything else and decide you want bigger and get a bigger turbo and then need new injectors, its a waste of money.
post #8 of 23 Old 01-16-2007, 05:58 PM
I'm still not seeing where you're pulling 302whp out of the stock turbo.
-Justin, aka Gomer
(sold)-05 WRX
post #9 of 23 Old 01-16-2007, 06:07 PM
the guy who put the turbo in his car was smokin some dank ganja and accidently gave him a vf34....hahaha
puple haze is the 302 actual or corrected?
post #10 of 23 Old 01-17-2007, 01:11 PM Thread Starter
Ijust read my post and oops.....i didnt mean 302whp.....I meant 302 bhp........I just looked at my dyno sheet and its 281whp.....so if my end goal is is to end up with a FMIC, APS sr40 turbo fuel rail/injectors/ etc. upgrade tranny first?...I am trying to determine how much the stock internals can handle before they need to be replaced.
I see some cars in mags and on the forums that push 350 whp with a clutch upgrade only, but most of them are STi's. the stock sti tranny is beefier than the stock WRX I suppose?
post #11 of 23 Old 01-17-2007, 01:50 PM
the stock sti tranny is completely different than the wrx. the magic number on the wrx tranny is 300whp. that is the number where you will have a big chance of breaking your trans. the sti tranny can hold 400+ whp if i am not mistaken.
with that setup you wont need to worry about building the ej25 up too much. maybe pistons/rods and arb studs. i may be wrong though.
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
post #12 of 23 Old 01-21-2007, 05:33 PM
jamr6s is an unknown
HP does not break transmissions. Torque does and the stock 6-speed is capable of 550wtq.
jamr6s is offline
post #13 of 23 Old 01-21-2007, 06:34 PM
mattxander12's Avatar
mattxander12 is an unknown
true. Where did you get that number ? Not challenging you, I'm just curious where you read it at etc. And at that torque number..... is that the maximum it can hold safely or is that just a recommended " don't go over this " number ?
mattxander12 is offline
post #14 of 23 Old 01-21-2007, 07:04 PM
hes running a wrx 5-speed not a sti......have fun with a car with 400whp and stock torque. if your gonna build the engine the transmission goes right along with it unless you have an sti and that still has its limits as you said.
Robby
02 rex is gone.
Evo is gone :(
Now I got nothing.
post #15 of 23 Old 01-26-2007, 01:41 PM
605wrx's Avatar
605wrx is an unknown
big valley's sti puts out 700+ whp w/the stock tranny but i'm not sure of his torque #'s, and from what i've read it's the torque that kills.
605wrx is offline
