Awesome Subi Build In the Making - Subaru WRX Forum
 7Likes
post #1 of 18 Old 01-10-2014, 09:47 PM Thread Starter
bmoney is an unknown
Hey guys I resurrected a very old thread of mine The time finally came...motor build! but thought it would just be easier to start a new thread. Here's the same post I posted on my old thread:
Haven't been on here in a long time but wanted to update everyone with my current set-up. It has been quite the journey the past few years with my subi but it will well be worth it in the end. I am currently on my 4th motor...I know right? :/
Stock blew due to crushed piston with turbo upgrade then the other 2 due to dropped sleeves...long story. As I still wanted a sleeved block, I went with Dan Benson Sleeves and sent my short block off last July and then received it back late October. Sleeves looked incredible!! Two thumbs up for Dan Benson!
After I had my first motor built I pulled 430whp/428wtq at 21 psi. Still had more to go but she overheated due to the sleeve dropping. Can't believe I got those numbers on my top mount. Stock motor was 385whp/378wtq.
Not to long after having received my block, my shop got broken into and my wheels and tires were stolen. Other cars in the lot didn't have it as good as I did, even though it still sucked!
Long story short, I decided to switch from the 5x100 to the 5x114 hubs. Scored a mint pair of the current sti 18 inch bbs wheels on ebay which I'm very happy about and am going to run 245/40/R18 Nitto NT-01 tires for the track this spring/summer. Went with Feal road race coilovers 10K front, 9K rear. Was going to go 12K/11K but still wanted to be able to utilize the coilovers as I won't run the Nitto's all year, as my subi is currently still my DD. Also added in some whiteline sways front(22mm) and rear (24mm).
My current mods:
Engine:
-Blouch 2.5 DOM XTR
-Turbo XS TMIC
-Grimmspeed EBCS 3-port
-ID 1000's
-MSI Fuel Rail Kit
-Tomei Fuel Pressure Regulator-Type L
-Tomei Fuel Pressure Gauge
-Dan Benson Sleeved Block
-High Compression Cosworth Forged 100mm Pistons (9:2:1 Compression)
-Cosworth Forged Rods
-Cosworth Main Bearing
-Cosworth Rod Bearing
-Nitrate Treated Crank
-ARP Head Studes
-Grimmspeed TGV Deletes
-Airpump Delete
-PnP Heads
-Kelford Cams 264/264
-Supertech Retainer Set
-Supertech Intake 1mm oversized valves
-Supertech Inconnel nickel base exhaust 1mm oversized valves
-Killerbee Oil Pickup
-Killer bee Oil Baffle
-Perrin Tubo Inlet
-Walbro 255lph Fuel Pump
-Group N engine mount
-Cobb TBE
-Cobb AP V2
-SPT intake
Drivetrain
-JDM V7 6 speed
-Group N tranny mount
-Clutch Masters FX400
-JDM V7 R180 rear diff
-5x114.3 hubs
-2012 OEM Sti BBS 18in wheels
-Feal Road Race Coilovers 10K front/9K rear
-Whiteline adjustable sway bars: Front (22mm) Rear (24mm)
-Kartboy front and rear end links
-06 Brembo Fronts and Rears
-DBA T-Slotted rotors front and rear
-Hawk HPS Brake Pads
Interior:
-OEM boost gauge
-AEM wideband AFR
Exterior:
-Stock
Soon to come:
-Fully custom FMIC
-GTX3582R
-Walbro 400lph fuel pump
-A/O separtor
-Nitto NT-01 tires 245/40/18
-New paint job
In the near future:
-Dry sump pump
-Status Ring FIA seats
-Status 6 point harnesses
-Roll Cage
-New DD
Car is currently still in the shop as I'm waiting on parts but should have it back in 2-4 weeks. Once I get the motor broken in, then I will add the "soon to come parts".
Hope you guys enjoy!
Brett
Dan Benson sleeved short block
Absolutely beautiful craftsmanship.
Fully assembled short block
Cosworth rods
Fully built heads
Supertech retainers
Close up of the PnP
New bbs wheels
There she is in the flesh, right after my rims were stolen
Brett
2006 WRX TR
Dom 2.5 XT-R
430 awhp 428 awtq
bmoney is offline
post #2 of 18 Old 01-10-2014, 10:30 PM
Why sleeved?
Also, that intake is holding you back.
post #3 of 18 Old 01-10-2014, 10:40 PM Thread Starter
Originally Posted by brfatal View Post
Why sleeved?
I had it sleeved for when I go rotated which will hopefully be after I break in my new motor. I'm wanting to push 700+ whp
Ya I know it is, but for the turbo I currently have it works fine. Obviously that intake will go when I go rotated
Brett
2006 WRX TR
Dom 2.5 XT-R
430 awhp 428 awtq
bmoney is offline
post #4 of 18 Old 01-11-2014, 11:28 PM Thread Starter
Input?
Hey guys would love to hear from you on my build so far. Always good to have other's inputs.
Thanks!
Brett
2006 WRX TR
Dom 2.5 XT-R
430 awhp 428 awtq
bmoney is offline
post #5 of 18 Old 01-12-2014, 03:48 AM
It sounds like it's turning into a track car.
post #6 of 18 Old 01-12-2014, 09:01 AM
Thanks!
You don't want mine.
man show and 06_hawk_eye like this.
post #7 of 18 Old 01-12-2014, 09:45 AM
Come on now, Keith... your hatred-infused posts bring us back to reality when we're feeling unusually happy.
psinuse, turmic and LW_Black4 like this.
post #8 of 18 Old 01-12-2014, 10:21 AM
Hatred infused??? Oh come one now there is no hatred here.
man show likes this.
post #9 of 18 Old 01-12-2014, 10:24 AM Thread Starter
That is my ultimate end goal. Need another vehicle though first before I install race seats, roll cage, harnesses, etc.
bmoney is offline
post #10 of 18 Old 01-12-2014, 10:27 AM Thread Starter
As long as you're not going to bash me for what ever reason I would like to have your input. I'm no expert by any means. I've always had a great experience from the community on this forum, hence why I'm still here.
bmoney is offline
post #11 of 18 Old 01-12-2014, 01:07 PM
Glad to see you're in the game still. Most people get out once they go big.
post #12 of 18 Old 01-12-2014, 02:39 PM Thread Starter
Thanks Kirt I appreciate it. It's been a long path and there's been times when I sincerely thought about getting out but tracking my car is something I've always wanted to do and I finally have the financial resources (for the most part) to start building a track car. I just want to go for it while I can.
Hows you're subi holding up these days? You still have that prototype blouch turbo?
Brett
2006 WRX TR
Dom 2.5 XT-R
430 awhp 428 awtq
bmoney is offline
post #13 of 18 Old 01-12-2014, 04:43 PM
It's still a one off...Dom3.0 XT-R (Not the one you can buy from their website). Been pretty dead on mods the past two years because my gf went back to college and then got married in October of this year. Now, we bought a house. Lol, so yeah. I hope soon I can start doing some suspension work or something. Just want to mod something again.
post #14 of 18 Old 01-14-2014, 10:46 PM
AUTOXING's Avatar
AUTOXING is an unknown
very nice, I am siting at 430whp/421wtq with a Garret GTX3071r. getting a short block built in may.
GO Big Or GO Home
2004 sti
AUTOXING is offline
post #15 of 18 Old 01-15-2014, 10:22 AM Thread Starter
Congrats on the marriage! Are you looking to do coilovers or upgraded struts? Ya man I was out of it for awhile as my car has just been sitting in the shop but its great to be back in it again.
Brett
2006 WRX TR
Dom 2.5 XT-R
430 awhp 428 awtq
bmoney is offline
