-   -   Awesome Subi Build In the Making (http://www.wrxtuners.com/forums/f103/awesome-subi-build-making-43665/)
bmoney 01-10-2014 09:47 PM
Hey guys I resurrected a very old thread of mine [URL="http://www.wrxtuners.com/forums/f103/time-finally-came-motor-build-31263/"]http://www.wrxtuners.com/forums/f103/time-finally-came-motor-build-31263/[/URL] but thought it would just be easier to start a new thread. Here's the same post I posted on my old thread:
Haven't been on here in a long time but wanted to update everyone with my current set-up. It has been quite the journey the past few years with my subi but it will well be worth it in the end. I am currently on my 4th motor...I know right? :/
Stock blew due to crushed piston with turbo upgrade then the other 2 due to dropped sleeves...long story. As I still wanted a sleeved block, I went with Dan Benson Sleeves and sent my short block off last July and then received it back late October. Sleeves looked incredible!! Two thumbs up for Dan Benson!
After I had my first motor built I pulled 430whp/428wtq at 21 psi. Still had more to go but she overheated due to the sleeve dropping. Can't believe I got those numbers on my top mount. Stock motor was 385whp/378wtq.
Not to long after having received my block, my shop got broken into and my wheels and tires were stolen. Other cars in the lot didn't have it as good as I did, even though it still sucked!
Long story short, I decided to switch from the 5x100 to the 5x114 hubs. Scored a mint pair of the current sti 18 inch bbs wheels on ebay which I'm very happy about and am going to run 245/40/R18 Nitto NT-01 tires for the track this spring/summer. Went with Feal road race coilovers 10K front, 9K rear. Was going to go 12K/11K but still wanted to be able to utilize the coilovers as I won't run the Nitto's all year, as my subi is currently still my DD. Also added in some whiteline sways front(22mm) and rear (24mm).
My current mods:
Engine:
-Blouch 2.5 DOM XTR
-Turbo XS TMIC
-Grimmspeed EBCS 3-port
-ID 1000's
-MSI Fuel Rail Kit
-Tomei Fuel Pressure Regulator-Type L
-Tomei Fuel Pressure Gauge
-Dan Benson Sleeved Block
-High Compression Cosworth Forged 100mm Pistons (9:2:1 Compression)
-Cosworth Forged Rods
-Cosworth Main Bearing
-Cosworth Rod Bearing
-Nitrate Treated Crank
-ARP Head Studes
-Grimmspeed TGV Deletes
-Airpump Delete
-PnP Heads
-Kelford Cams 264/264
-Supertech Retainer Set
-Supertech Intake 1mm oversized valves
-Supertech Inconnel nickel base exhaust 1mm oversized valves
-Killerbee Oil Pickup
-Killer bee Oil Baffle
-Perrin Tubo Inlet
-Walbro 255lph Fuel Pump
-Group N engine mount
-Cobb TBE
-Cobb AP V2
-SPT intake
Drivetrain
-JDM V7 6 speed
-Group N tranny mount
-Clutch Masters FX400
-JDM V7 R180 rear diff
-5x114.3 hubs
-2012 OEM Sti BBS 18in wheels
-Feal Road Race Coilovers 10K front/9K rear
-Whiteline adjustable sway bars: Front (22mm) Rear (24mm)
-Kartboy front and rear end links
-06 Brembo Fronts and Rears
-DBA T-Slotted rotors front and rear
-Hawk HPS Brake Pads
Interior:
-OEM boost gauge
-AEM wideband AFR
Exterior:
-Stock
Soon to come:
-Fully custom FMIC
-GTX3582R
-Walbro 400lph fuel pump
-A/O separtor
-Nitto NT-01 tires 245/40/18
-New paint job
In the near future:
-Dry sump pump
-Status Ring FIA seats
-Status 6 point harnesses
-Roll Cage
-New DD :D
Car is currently still in the shop as I'm waiting on parts but should have it back in 2-4 weeks. Once I get the motor broken in, then I will add the "soon to come parts".
Hope you guys enjoy!
Brett
[IMG]http://imagizer.imageshack.us/v2/800x600q90/809/g69e.jpg[/IMG]
Dan Benson sleeved short block
[IMG]http://imagizer.imageshack.us/v2/800x600q90/845/qwzb.jpg[/IMG]
Absolutely beautiful craftsmanship.
[IMG]http://imagizer.imageshack.us/v2/800x600q90/69/p6xq.jpg[/IMG]
Fully assembled short block
[IMG]http://imagizer.imageshack.us/v2/800x600q90/838/szix.jpg[/IMG]
Cosworth rods
[IMG]http://imagizer.imageshack.us/v2/800x600q90/19/l5ms.jpg[/IMG]
Fully built heads
[IMG]http://imagizer.imageshack.us/v2/800x600q90/834/kgdu.jpg[/IMG]
Supertech retainers
[IMG]http://imagizer.imageshack.us/v2/800x600q90/844/95ah.jpg[/IMG]
Close up of the PnP
[IMG]http://imagizer.imageshack.us/v2/800x600q90/6/oo5x.jpg[/IMG]
New bbs wheels
[IMG]http://imagizer.imageshack.us/v2/800x600q90/716/14ge.jpg[/IMG]
There she is in the flesh, right after my rims were stolen
brfatal 01-10-2014 10:30 PM
Why sleeved?
Also, that intake is holding you back.
bmoney 01-10-2014 10:40 PM
[quote=brfatal;422529]Why sleeved?
Also, that intake is holding you back.[/quote]
I had it sleeved for when I go rotated which will hopefully be after I break in my new motor. I'm wanting to push 700+ whp
Ya I know it is, but for the turbo I currently have it works fine. Obviously that intake will go when I go rotated
bmoney 01-11-2014 11:28 PM
Input?
Hey guys would love to hear from you on my build so far. Always good to have other's inputs.
Thanks!
turmic 01-12-2014 03:48 AM
It sounds like it's turning into a track car.
psinuse 01-12-2014 09:01 AM
[quote=bmoney;422673]Hey guys would love to hear from you on my build so far. Always good to have other's inputs.
Thanks![/quote]
You don't want mine.
man show 01-12-2014 09:45 AM
Come on now, Keith... your hatred-infused posts bring us back to reality when we're feeling unusually happy.
psinuse 01-12-2014 10:21 AM
[quote=man show;422729]Come on now, Keith... your hatred-infused posts bring us back to reality when we're feeling unusually happy.[/quote]
Hatred infused??? Oh come one now there is no hatred here. :D
bmoney 01-12-2014 10:24 AM
[quote=turmic;422681]It sounds like it's turning into a track car.
[color=gray]Sent from [url=http://www.autoguide.com/mobile]AutoGuide.com Free App[/url][/color][/quote]
That is my ultimate end goal. Need another vehicle though first before I install race seats, roll cage, harnesses, etc.
bmoney 01-12-2014 10:27 AM
[quote=psinuse;422705]You don't want mine.[/quote]
As long as you're not going to bash me for what ever reason I would like to have your input. I'm no expert by any means. I've always had a great experience from the community on this forum, hence why I'm still here.
turmic 01-12-2014 01:07 PM
Glad to see you're in the game still. Most people get out once they go big.
bmoney 01-12-2014 02:39 PM
[quote=turmic;422785]Glad to see you're in the game still. Most people get out once they go big.
Thanks Kirt I appreciate it. It's been a long path and there's been times when I sincerely thought about getting out but tracking my car is something I've always wanted to do and I finally have the financial resources (for the most part) to start building a track car. I just want to go for it while I can.
Hows you're subi holding up these days? You still have that prototype blouch turbo?
turmic 01-12-2014 04:43 PM
It's still a one off...Dom3.0 XT-R (Not the one you can buy from their website). Been pretty dead on mods the past two years because my gf went back to college and then got married in October of this year. Now, we bought a house. Lol, so yeah. I hope soon I can start doing some suspension work or something. Just want to mod something again.
AUTOXING 01-14-2014 10:46 PM
very nice, I am siting at 430whp/421wtq with a Garret GTX3071r. getting a short block built in may.
GO Big Or GO Home
2004 sti
bmoney 01-15-2014 10:22 AM
[quote=turmic;422801]It's still a one off...Dom3.0 XT-R (Not the one you can buy from their website). Been pretty dead on mods the past two years because my gf went back to college and then got married in October of this year. Now, we bought a house. Lol, so yeah. I hope soon I can start doing some suspension work or something. Just want to mod something again.
Congrats on the marriage! Are you looking to do coilovers or upgraded struts? Ya man I was out of it for awhile as my car has just been sitting in the shop but its great to be back in it again.
