Aftermarket Heads 2002 EJ20 - Subaru WRX Forum
post #1 of 14 Old 01-10-2008, 05:47 PM Thread Starter
jaygunn is an unknown
I had a water pump go while I was out of town and my car (2002 WRX) was with a friend. Once I got it to the shop, we found the radiator cracked, head gaskets blown and now I just had the heads pressure checked only to find they are bad too. I have searched for an answer and not found what I'm looking for. I work 2 jobs and I'm deploying overseas very shortly. I would like to have this issue resolved before I go. If anyone knows of good aftermarket heads, I would appreciate a point in the right direction.
jaygunn is offline
post #2 of 14 Old 01-10-2008, 06:17 PM
Best bet is to look for a set of stock heads. Otherwise your looking at a huge chunk of change for a set of heads. Cobb's start at $3500 I believe.
post #3 of 14 Old 01-10-2008, 07:10 PM Thread Starter
That's a huge difference in price. Is the performance worth the price?
jaygunn is offline
post #4 of 14 Old 01-10-2008, 07:24 PM
Depends on your mods. Heads make power, but if your not going big then I wouldn't spend the money yet.
post #5 of 14 Old 01-10-2008, 07:37 PM Thread Starter
Sounds good. My mods aren't to the point of needing them yet. Thanks for the help.
jaygunn is offline
post #6 of 14 Old 01-11-2008, 02:35 PM
the stock heads are actually a pretty good design. I'd recommend just replacing with OEM heads. many ppl get 350whp out of the stock heads without issues.
post #7 of 14 Old 01-11-2008, 10:26 PM
wrxman420's Avatar
There is no need to spend 3500 on a set of heads. A better option would be to get some oem heads and port them out, and if you really want to... get a valvetrain kit with cams.
wrxman420 is offline
post #8 of 14 Old 01-11-2008, 10:33 PM
b7g
b7g's Avatar
b7g is an unknown
...or jdm sti 2.0 heads...
drive = freedom
b7g is offline
post #9 of 14 Old 01-11-2008, 11:49 PM
bare stock heads are 1500 from subaru
nagyhead is offline
post #10 of 14 Old 01-12-2008, 01:26 AM
king723 is an unknown
+1 but the v7 v8 heads have avcs and you will need to run the hydra tuner and thats $$$$ right there..
but check nasioc in the parts section and you will be able to find a good set of heads.
king723 is offline
post #11 of 14 Old 01-12-2008, 02:39 PM
You don't have to run AVCS or a Hydra to use JDM heads. It still is nice, but if your looking for replacement heads get a set of used heads and have them cleaned then slap them on the motor and be done with it, maybe throw in a good valvetrain while there out.
post #12 of 14 Old 01-12-2008, 05:08 PM
wrxman420's Avatar
Correct me if i am wrong, but i think all you need to run avcs is the jdm ecu.
post #13 of 14 Old 01-12-2008, 07:05 PM
You can just use a JDM ECU with a few minor map revamps, mostly for emissions if I remember correctly.
post #14 of 14 Old 01-12-2008, 08:08 PM
b7g
b7g's Avatar
b7g is an unknown
... and to run on lower octane fuel...
drive = freedom
b7g is offline
