-   -   Aftermarket Heads 2002 EJ20 (http://www.wrxtuners.com/forums/f103/aftermarket-heads-2002-ej20-21764/)
jaygunn 01-10-2008 05:47 PM
I had a water pump go while I was out of town and my car (2002 WRX) was with a friend. Once I got it to the shop, we found the radiator cracked, head gaskets blown and now I just had the heads pressure checked only to find they are bad too. I have searched for an answer and not found what I'm looking for. I work 2 jobs and I'm deploying overseas very shortly. I would like to have this issue resolved before I go. If anyone knows of good aftermarket heads, I would appreciate a point in the right direction.
psinuse 01-10-2008 06:17 PM
Best bet is to look for a set of stock heads. Otherwise your looking at a huge chunk of change for a set of heads. Cobb's start at $3500 I believe.
jaygunn 01-10-2008 07:10 PM
That's a huge difference in price. Is the performance worth the price?
psinuse 01-10-2008 07:24 PM
Depends on your mods. Heads make power, but if your not going big then I wouldn't spend the money yet.
jaygunn 01-10-2008 07:37 PM
Sounds good. My mods aren't to the point of needing them yet. Thanks for the help.
mosc 01-11-2008 02:35 PM
the stock heads are actually a pretty good design. I'd recommend just replacing with OEM heads. many ppl get 350whp out of the stock heads without issues.
wrxman420 01-11-2008 10:26 PM
There is no need to spend 3500 on a set of heads. A better option would be to get some oem heads and port them out, and if you really want to... get a valvetrain kit with cams.
b7g 01-11-2008 10:33 PM
[QUOTE=wrxman420;182828]There is no need to spend 3500 on a set of heads. A better option would be to get some oem heads and port them out, and if you really want to... get a valvetrain kit with cams.[/QUOTE]
...or jdm sti 2.0 heads...
nagyhead 01-11-2008 11:49 PM
bare stock heads are 1500 from subaru
king723 01-12-2008 01:26 AM
[QUOTE=b7g;182829]...or jdm sti 2.0 heads...[/QUOTE]
+1 but the v7 v8 heads have avcs and you will need to run the hydra tuner and thats $$$$ right there..
but check nasioc in the parts section and you will be able to find a good set of heads.
psinuse 01-12-2008 02:39 PM
[QUOTE=king723]+1 but the v7 v8 heads have avcs and you will need to run the hydra tuner and thats $$$$ right there..
[/QUOTE]
You don't have to run AVCS or a Hydra to use JDM heads. It still is nice, but if your looking for replacement heads get a set of used heads and have them cleaned then slap them on the motor and be done with it, maybe throw in a good valvetrain while there out.
wrxman420 01-12-2008 05:08 PM
Correct me if i am wrong, but i think all you need to run avcs is the jdm ecu.
psinuse 01-12-2008 07:05 PM
You can just use a JDM ECU with a few minor map revamps, mostly for emissions if I remember correctly.
b7g 01-12-2008 08:08 PM
[QUOTE=psinuse;182878]You can just use a JDM ECU with a few minor map revamps, mostly for emissions if I remember correctly.[/QUOTE]
... and to run on lower octane fuel...
