-   -   2002 EJ25 back to EJ20 ? (http://www.wrxtuners.com/forums/f103/2002-ej25-back-ej20-28147/)
SeanDead 02-10-2010 01:24 PM
Hey guys, I'm fairly new to the WRX tuning world. Not so new to the tuning scene.
Anyway, ill get to the point.
I just bought a 2002 WRX (vin code correct) It says it had a EJ205AW3B9
Tanny says TY75VN2AA.
Pretty much, i bought it from the guy that said it probably had a blown head gasket, So i ended up taking the block out, to check for a blown head gasket .
Well, to my surprise, i find that cylinder #3 (It has a reputation) has rough spots on the wall, and signs of blow by.
My prognoses, it was a EJ25RS block (newer?) Its stamped with EJ25. That has non turbo pistons ect, That was converted to a turbo block. and i think thats why it got blown. It also has DOHC, which isnt stock for the 02 WRX.
It has signs of oil in the coolant, and coolant in the oil. I checked the metal gaskets, no signs of a blown one.
So i have three options, I could spend the money rebuilding, rehoneing the EJ25 block, new actual turbo pistons, resurface the DOHC heads.
Or i can buy a JDM low mileage EJ20 turbo short block, sell my DOHC heads and put SOHC. on there for gas milage, and better internals
And i will leave my number 3 option to you guys.
Whats your opinion? EJ25RS or EJ20 turbo block?
Bloth blocks and wiring harnesses/manifolds ect should work between each block right?
I appreciate it.
mosc 02-10-2010 02:16 PM
well, I am not following what's under your hood. Assuming you had the proper heads from the EJ205, I'd say build an EJ205/EJ257 hybrid. Sounds like your whole EJ205 was ripped out in favor of some never-should-have-been-turboed 2.5RS motor? In that case, you'll need something more complete so a used EJ207 sounds like a very good idea. What's under your hood? Did they even use a TD04 turbo/wrx intercooler?
SeanDead 02-10-2010 02:22 PM
Its the 2002 WRX, The only thing i notice that isn't the same is the block, 2.5RS With DOHC (I don't know how to tell what kind of cams it is from) it has the TMIC intercooler/TD-04 turbo, everything.
I've had a lot of people tell me get a closed deck 2.5
but a lot swear by the EJ20 closed deck turbo.
I do intend on adding boost to it.
mosc 02-10-2010 02:26 PM
First of all, the EJ257 and EJ207 are not closed deck. It's semi-closed. The last real "closed" deck turbo motor is the EJ22.
I don't know what kind of heads you have. If you need to replace them, get a JDM motor. If you don't, grab a EJ257 shortblock (usdm sti) and go from there.
SeanDead 02-10-2010 02:33 PM
Sorry, I ment semi closed deck. Lol
Ill look into it, Thanks.
WTRacing 02-10-2010 03:37 PM
it sounds to me that someone already had a hybrid in there and the 02 wrx was dohc you need to get the casting number off the heads but i think your gonna find that they are ej205 heads
SeanDead 02-10-2010 04:50 PM
[quote=WTRacing;240014]it sounds to me that someone already had a hybrid in there and the 02 wrx was dohc you need to get the casting number off the heads but i think your gonna find that they are ej205 heads[/quote]
Were are the casting numbers located at?
I.e any examples?
I've seen a few stamps but nothing sufficient..
Thank you.
WTRacing 02-10-2010 05:53 PM
they are on the exhaust side should look something like this
[IMG]http://i86.photobucket.com/albums/k105/btronco1/heads02.jpg[/IMG]
SeanDead 02-10-2010 08:35 PM
LH or RH and it says B 004
Those are the only stamps on it.
Which means?
WTRacing 02-11-2010 01:38 AM
im 99% sure its ej20 heads
mosc 02-11-2010 11:02 AM
Then grab an EJ257 shortblock.
WTRacing 02-11-2010 06:06 PM
get a shortblock stock or built and call it a day
