13000 miles Piston broken... 07 WRX - Subaru WRX Forum
post #1 of 6 Old 01-04-2008, 02:03 PM Thread Starter
Jonpark is an unknown
Send a message via MSN to Jonpark
The car went through compression test the other day and came out to be something wrong... #4 cylinder was reading 25psi.
so now yesterday my tuner ordered the STi Short block instead of getting a forged pistons...
now...what are the Ups and Downs for this block?
i know definately the sti block takes more boost level but what else?
291.11whp/321.13wtq 18psi
Jonpark is offline
post #2 of 6 Old 01-04-2008, 02:21 PM
96accord's Avatar
96accord is an unknown
Send a message via AIM to 96accord Send a message via Yahoo to 96accord
What mods do you have??
Stage 2? ECU/AP? TBE? Pro-tune? Turbo?
96accord is offline
post #3 of 6 Old 01-04-2008, 03:01 PM Thread Starter
I have Protune(enginuity)
VF39
all the Perrin hoses( for intercooler, turbo)
SPT intake
Perrin V2 fuel rail
XO2 TMIC
Optima red top battery
Perrin Crank pulley
Perrin Equal length headers
AEM alcohol injection system
Helix Catted DownPipe
Blitz Nurspec RX catback
HKS SSVQ BOV(new version)
Jonpark is offline
post #4 of 6 Old 01-04-2008, 09:18 PM
What boost levels were you running at?
nagyhead is offline
post #5 of 6 Old 01-05-2008, 11:35 AM Thread Starter
before alcohol injection 18psi
after alcohol injection 20 psi
Jonpark is offline
post #6 of 6 Old 03-12-2008, 07:01 AM
pddvl1's Avatar
pddvl1 is an unknown
your o7 already has the sti bottom end with the stock pistons that cracked the ring lands it overboosted, keep it under 17 psi and have your tuner lower the timing before it knocks run good 91 not the cheapest gas station and you should be fine, you can also just replace the affected piston and rings if the cylinder wall is not damaged and it will be fine thats the way the dealers do it
pddvl1 is offline
