-   -   13000 miles Piston broken... 07 WRX (http://www.wrxtuners.com/forums/f103/13000-miles-piston-broken-07-wrx-21689/)
Jonpark 01-04-2008 02:03 PM
The car went through compression test the other day and came out to be something wrong... #4 cylinder was reading 25psi.
so now yesterday my tuner ordered the STi Short block instead of getting a forged pistons...
now...what are the Ups and Downs for this block?
i know definately the sti block takes more boost level but what else?
96accord 01-04-2008 02:21 PM
What mods do you have??
Stage 2? ECU/AP? TBE? Pro-tune? Turbo?
Jonpark 01-04-2008 03:01 PM
I have Protune(enginuity)
VF39
all the Perrin hoses( for intercooler, turbo)
SPT intake
Perrin V2 fuel rail
XO2 TMIC
Optima red top battery
Perrin Crank pulley
Perrin Equal length headers
AEM alcohol injection system
Helix Catted DownPipe
Blitz Nurspec RX catback
HKS SSVQ BOV(new version)
nagyhead 01-04-2008 09:18 PM
What boost levels were you running at?
Jonpark 01-05-2008 11:35 AM
before alcohol injection 18psi
after alcohol injection 20 psi
pddvl1 03-12-2008 07:01 AM
your o7 already has the sti bottom end with the stock pistons that cracked the ring lands it overboosted, keep it under 17 psi and have your tuner lower the timing before it knocks run good 91 not the cheapest gas station and you should be fine, you can also just replace the affected piston and rings if the cylinder wall is not damaged and it will be fine thats the way the dealers do it
