05 wrx no compression. - Subaru WRX Forum
post #1 of 2 Old 12-26-2014, 11:57 PM Thread Starter
hello, im having a huge issue with my 05 subaru wrx hybrid swap. i was having some valve issues so i bought brian crower valves timing belt new gaskets the works. installed everything and went to start it nothing.. just a whine i tried doing a compression test and every cylinder has 0 psi! 0! it wont even move if i tried to crank it nothing is hitting im so lost on this ive never seen anything like it in my life. quick responsed need help thanks everyone!
Josh Sharp is offline
post #2 of 2 Old 12-31-2014, 05:14 PM
fastwayracing's Avatar
Recheck your timing marks.. When you did the head swap did you check the valve clearances?
fastwayracing is offline
